[TABLE="width: 1242, align: center"] [TR] [TD]I have for sale my carbon bonnet that I had on my Mk2 Megane (2002 - 2008) during summer months only. I am going to leave on the washer jets, pipe work as seen and the bonnet catch / bonnet release which I purchased extra onto of the bonnet cost. IIRC I think the bonnet was about £650 and then the other bits I approximate at £50. There are some stone chips, as can be seen in the pictures (white marks) as all used clear coated carbon suffers with. The lines on the bonnet are where I had just given it a wipe with a damp cloth. The white squares you can see on the underside are the remains of the self adhesive pads I had holding the washer pipe on. To get the bonnet mint again you could sand back the clear coat and re coat it (approx £100) or you could paint it to match your car, or just use it as it is as I have done. I would like collection for this item, but you are welcome to send a courier as the bonnet is still in its original box, but due to the nature of the item this would be entirely at your own risk. [/TD] [/TR] [/TABLE] The lowest I would go on this with no messing around is £280 cash. This is a full composite bonnet, not a metal bonnet with a wrap.
Arrank - thanks for the offer, I really need to get £280. Maccy - sorry no idea on weights. I can try and weigh this later but Im unsure of a standard one.
