Car jerking
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Leeccfc1992, Apr 17, 2016.
  1. Hi guys , now and again I get a whining whislt pulling off using the clutch only no gas , also getting a jerk back when letting of the throttle ( changed all mounts ) any help would be appreciated Lee
  2. dmf possibly
  3. Not cheap then :/ would it be ok to carry on driving or replace asap??
  4. no not cheap just keep driving untill it goes mate , have you had the mounts checked as your could have a faulty one .. ?
  5. I've not had them checked no , there's no movement in the dog one mount , although LH under battery tray mount needs replacing but can't see this causing the issue? Thanks
  6. well thats the gearbox mount and that was the one that gave me the same issue so its likely mate :smile:
  7. Changed last mount of the 4 today slightly better , guessing it is dmf then :/
