225 Can this be removed ?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Mikey4410, Oct 11, 2017.
  1. Mikey4410
    Mikey4410 Guest
    Hey guys.i heard this is an emissions thing and can be removed and vac hoses plugged as i wanted to make up a catch tank setup as a pose to the oil going back round into the intake etc
  2. Did you find anything out on this Mikey??
  3. Mikey4410
    Mikey4410 Guest
    Yeah andy at e.d said if you remove the actual bit that the plug goes into u will get an engine light so if you removed where all the hoses went and did a catch can setup etc i guess u cud run a multimeter across the unit and see what resistance it is and get a resistor in there and hide that away somewhere.....i havent done anything as yet but i do still plan to if im honest. If i do i will let u know on this thread
