I'd expect to pay £450 - £500 for all belts and water pump, and as far as £600 if you want oils and brake fluid too.
Oh and I should also ask, does this require the special timing tool and therefore is best done by a specialist?
Don't need a specialist to do them done myn myself fair enough I used to work for a renault dealership but never worked on a 225 untill I got myn. But yeah u need the locking tools
Mark Black who posted above you is a Renault Sport specialist, is as cheap as anyone and cheaper than most, and knows these cars inside out. And you're not that far away.
Yeah I've heard of Mark off here and Cliosport.net. I'm looking at a couple of 225s and one of them would need cambelt doing if I went for that one so that's a good shout.
Local Renault dealership just told me 7.5 hours labour! Lifestyle Renault in T. Wells want £1,186.74 and are clearly having a laugh!
i was quoted around £700 from my main renault dealer, as above though, Mark Black will sort you out, top chap
I have been quoted 585 for belt kit and coolant change and water pump at revolution in Gateshead Newcastle
Mark black is def where I'll be heading and I'm in Newcastle.. I'd never use revolution for anything after the issue i had with them
