Car resonates alot through the cabin on idle. Feel like a giant bibrator at the lights some times. not been out to check any mounts which ones are most common to fail on these will it just be the stabiliser bar or main engine mount. Just helps me out if need to rip battery tray out to test that one and so forth. Thanks for your input
Yeah,i agree with your points,these are the main points for this vibration so take it quickly to the mechanic,he knows well about the problem,if you late it so it would be worse for your car.
I have this, nice to find out whats the cause then! Is the solution a new mount or is it case of the old one working loose?
In the mk2's it a case of the rubber in the mount wearing out so new mount I'm not sure if the mk3's are the same
