Hi all Fitted a forge recirc valve a few months ago and around the time mid box delete too Followed up by a ktec induction kit this afternoon. It’s given me the sound i was looking for from induction/turbo/exhaust perspective I think perhaps the sound is pronounced with the sound generator. Have looked across the web and threads for a link to a bung, struggling to find one can anyone link me one please? cheers
Did you sort this? I wanna get rid of the sound pipe on my car, Why do you need 2 32mm bungs? Thought I'd only 1 pipe to bung up? https://www.toolstation.com/push-fi...q3Cx3Ms5OP_Fm6J-TfIIWDOX0V4qCnG8aAnteEALw_wcB
I bought a 32mm one of these for mine. https://www.ebay.co.uk/itm/Alloy-Ho...hash=item4aee67e6d3:m:mp6i8ZEo73-HEQwocvutTLQ
So you only need one? I thought as much. Its only a pipe Init. Not alot of pressure comes through? Any old bung should do long as it stops air coming through.
Yes just the one, i didn't cut the pipe back, just removed the generator and shoved this in the end and secured it with a Jubilee clip. It will be max boost pressure, with the one i posted a link to has barbs to stop it coming out without over tightening the clip.
Ah okay needs barbs. I'll grab one at some point. Need to change old intake pipe might do it then cheers
got 2 myself only because i got rid of the pipe altogether. Top side is easy enough accessible, the bottom part turned out to be a bit more tricky to access but got there in the end and bunged both sides up 32mm was spot on, nice and snug
Its a sound thingy. It's next to the air box. In the gap between the block and the air box. Mind my skanky engine on my todolist. View attachment 33000 The black plastic pipe thingy. That says Renault on our. Next to the power stearing fluid box. You take it of there are two bolts I think. And it's attached to a pipe at the bottom. You put the plug it that. If you swap in a dump valve from forge and the full spring recir one I think. They tell you how to remove it. It's fairly simple.
