hi the bumper on my r26 keep coming loose and popping out where it meets the front wing. the screw in the inner arch was missing but having put another in i suspect theres some damage behind which means the thread that the screw screws into is missing or damaged. can't seem to find a drawing of how it all fits together to see hope i can fix it. any ideas? cheers
There is a bracket on the bumper that the top arch lining screw should screw into, sometimes this bends when mounting the bumper and causes this area to pop out. You should be able to sort it without removing the whole bumper, just take out the top screw and pull it out a bit and manipulate the bracket into the correct place and refit screw.
