Budget tyre problem
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by deano9621, Jun 28, 2020.
  1. I've had an issue with my esp/asr light flashing for a while now...and it does flash for only a few seconds but only at low speeds and turning right mostly....but today I think I've found possibly the cause...since I had the car it has had budget tyre's on the rear only...but I never thought it could possibly be the cause of the problem...so I checked the pressure of each tyre which was about 32psi on each so I lowered this to 28psi on both and since then had no issues at all :wink:. I hear from somewhere that budget tyre's can cause this issue and over inflation.. is this true ?
    Any thoughts?
  2. And also at higher speeds it felt too light on back end and never had this issue before with any Mégane 2 sport ?
