225 Broke Down Yesterday!
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Danp, Jun 23, 2014.
  1. Left my house yesterday morning heading to the coast and about 10 minutes later this happened
    Not happy!
    The pressure sensor had come off. I think that is what it is called. It goes next to the pipe which has the dump valve on it.
    Now I see forge do a clamp set to keep it in but the AA man said that I may need "an O ring" aswell. I have had a look and both clips that hold the sensor in are gone so basically what do I need guys? Can I get away with just the forge clamps or do I need something else aswell?
  2. Happened to me too. Originally I replaced the rubber o ring and cable tied it down, which worked but didn't look nice. I have since got the forge clamps and they work perfectly :smile:
  3. Where can I get a rubber o ring from? And what size do I get?
  4. I can't remember, I had random sizes laying around my garage so luckily I found one to fit. Any local diy store should sell o rings, and they are usually pennies. Either take your sensor with you or just but a few and see what works.
  5. ok thanks mate
  6. You should be able to replace the whole pipe from renault a lot of people break that clip fitting dump valves
  7. The whole pipe is about £42 from Renault, I bought one about 6 months ago when my clips broke.
