225 Brembo dust seal replacement
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by maece82, Mar 28, 2022.
  1. Might it be an easy job to replace all 4 brake piston dust seals on a Megane 225 Brembo caliper, whilst doing a disc and pad change?
    Is it only removal of old dust seals with a spiky tool and pushing new seals in by hand? Or might it be kind of a can of worms?
    Many thanks
    Marcel
  2. Its an easy job to change the dust seals, even changing the piston seals aren't that bad
  3. It's a difficulty score of 3 on a 1-10 scale.
    Hardest part is getting the pistons out of the caliper. An air line is the easiest way, or you can use a bicycle tyre pump with a suitable connector.
