225 Breather pipe.
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by discoken, Sep 30, 2020.
  1. Hi guys.
    This breather pipe on my 225 is broken and has been repaired with rubber hose. There is a check valve in the middle. Can anyone confirm if this is meant to be a one way valve and if so which way would it flow? The valve has been cleaned but I can blow through it in both directions. Thanks.
  2. Better photo. This is the valve in question.
  3. yes one way, check there should be small arrow indicating flow direction
  4. Cheers mate. Thanks for your help.
