Had cambelt changed 2 weeks ago, ABS message came up and got after a few re-starts. Now a red "braking system fault" light has appeared? Any ideas what this could be?
Mine does exactly Mine does exactly the same only stays on for a short time, also says STOP its a bit disconcerting.
I think your best bet is to connect it to OBD2 and see what fault code it reads, so you know where to look.
If it's this, you should check if the drain plugs are working as they should, they are the small holes in the plastic corners under the window wipers. If they get blocked water can build up and cause problems
Checked brake fluid and its showing at max.... Next is to connect it to obd2 at garage to get it checked out
I ve been to my local car guru and he has looked at various different things, It turns out I need new discs all round so now its a question of what to buy and where from? Cheers for the replies.
