brake vacum fitting
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by harveym3, Jun 12, 2016.
  1. hi all i need a new vacum fitting that fits into the throttle body as mine has fallen apart anyone now the part number or have one .
  2. help
  3. Be easier if you could upload a pic of the bit that's broke and where it goes.. but here goes..
    Is it on this diagram ?
    or do you mean the bit that goes into this hole on the TB:
    if it's that one it's part #1 in the diagram below - part num 8200549111 - a common problem and you should also buy the K-Tec or Forge vacuum pipe clamps to go with it...
    Note the diagram in dialogys above actually displays wrong, but that's the correct part number
  4. that's the bit ill ring renault to day thanks mate
  5. well I nearly feel over but renault won't £48 for that pipe so I might need a 2nd hand one or have it taped and make my own
  6. I have done mate thanks
