R26 Brake pedal gone weird
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by novakgtx, Sep 19, 2014.
  1. Driving home from work tonight and my brake pedal started to go lower and lower to the floor before the brakes would engage then it went fine for 5 mins then slowly got lower to the floor again like there is no pressure, i checked for any signs of leaks couldn't find any and checked my brake fluid level still at the full mark if any one got any suggestions would reallly appreciate it as this is my daily driver!
  2. Have you tried bleeding the brakes, air in the system ?
  3. Ive done the front callipers no air present in the lines pedal still lowers with hardly any pressure behind it
  4. Have u bled them in sequence?
  5. Their is an inner and outer on the Brembo fronts, you done both sides
  6. yeah i did the outer bleed nipple then the inner on both im thinking is it the brake servo or master cylinder
