Brake fluid advice
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Lukec4s, Feb 23, 2025.
  1. Hi all,
    I have a Megane r26 and want to change the brake fluid myself, I plan to change pads and discs which I’m fine doing but have a few questions regarding the brake fluid change. Is someone able to guide me through this ?
    my issues are I have read the ABS pump needs to be cycled to open? If so is there a cheap app to use?
    Also as the clutch is fed off the same fluid I mindful of air getting into clutch line, I have read this can be bled below battery area but sounds difficult. Is bleeding the clutch fluid necessary ?
    cheers
