Box info
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by kart27, Apr 10, 2017.
  1. Is there any differences between the R26 box and a 250 Cup box?
  2. Two completely different boxes, think the 250 is longer.
    kart27 likes this.
  3. I have a friend trying to source a R26 box and thought possibly the 250 box was the same.
  4. Longer as in casing dimensions or longer in gear ratios?
  5. -Jamie-
    Not sure on gear ratios but the PK4 box that the Mk3's use is a fairly big box, hence you cant really fit them to a Clio if doing Megane conversion.
    Should fit in a Mk2 Megane though, the DCi uses the same box IIRC
    kart27 likes this.
  6. All correct but the PK4 is also fitted to the 2.0 DCI megane 2 so it should fit within R26 engine bay.
    However the fit to the F4Q block is a different story on which i cannot comment on as i don't know.
    kart27 likes this.
  7. -Jamie-
    That's what I said [emoji23]
  8. Thanks guys
  9. What about the differences in 225 box and R26 box? Is it really the same box but R26 has a diff fitted inside it?
  10. -Jamie-
    I'm not sure clued up on the MK2s, LSD for definite though, ratios might be different but I couldn't tell you
    kart27 likes this.
  11. Sorry but i thought you meant 2.0dci Mk3 megane rather than MK2.
    Nevermind, we got there in the end...:tearsofjoy::tearsofjoy::tearsofjoy:
  12. Si.
    Si.
    Ph 2 225 (Ph1 box has a deifferent selctor on so not sure if these can be swapped) and R26 boxes are the same just the R26 has the diff. Seen a lot of people put the R26 diff straight into a 225 box with no issues
  13. So a 250 cup (LSD) box would go on a dci 175!?!
    RS 175 Cup Lux
