Bottom engine mount
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Ashley, Jul 5, 2017.
  1. No, it only to stop the engine swinging backwards and forwards
  2. What Ryan said, its easy to replace.
  3. Cheers for quick reply guys
  4. I always find replacing it with an uprated mount is the way to go, either the vibra one or inserts, vast improvement.
  5. I'm assuming PFF60-526 kit is the only replacement powerflex do ?
  6. Depends if you have a black rubber coated older mount and can use inserts or if you have a cast mount in which case you need to press out the old rubber bit to fit the replacement. From memory I think you number is for the replacement and newer cast mount.
  7. I've got the newer mount brand new sitting in the boot of the car typical lol I bet that's the more expensive one to get the poly bushes for
  8. Yep. PFF60-526 £54.
