boost gauge install ?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by nahalcko, Oct 26, 2014.
  1. Hello guys,
    I have a mechanical (pressure hose type) boost gauge that a friend gave me long time ago, but I dont know how to install it. Ive read about it, but I am not very sure how to install it. So can some one post a few pictures and explain, where to connect the tube and the cables, I will be very thankfull.
    thank you very much.
  2. On any silicon pipe on the block, just disconect one with the engine on a u should ear air flow coming from the pipe conect there the gauge and u should get a negative presure, about -12 psi. From there just extend a pipe using a T housing pipe to the cabin
  3. thanks!! Is there a plase where the pipe can go true the firewall and where do I connect the wires
  4. I used a hole next to the cluth pedal, or u could just do one
