Boost drops at 5k
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Shaunkealaher, Dec 19, 2015.
  1. Got a ph1 meg 225 and the boost drops at 5k goes to 6k and just splutters nowhere near the limiter hits limiter fine if i just rev it at a stand still up to full temp changed coils plugs injectors all vac pipes...got a forge dv with a yellow spring im on standard boost would the yellow spring cause this ? Thanks in advance
