Do any people have these fitted to there meganes I ran the blitz one in my 2 x evos and rated it Peak boost etc and can turn the gain up etc a tad when needed Any pics in these meganes cheers
If you're just wanting to see if you're hitting it's full potential boost, then get a boost gauge or scan gauge.
Boost controller dont work on the megane, I tried too. The ecu controlls the boost even when u tried to modified it
Boost controller does work on the megane. Both myself & Paul at Rs tuning ran the blitz spec r icolour ones. Mine was running about 320bhp & Paul's was running over 500bhp. Lee
You bypass the n75 valve as that is what is controlling the boost. It is not advisable unless your car has been re-mapped though. Lee
Wouldn't it be more advisable to raise the boost by remap and not separate boost controler, I woukd like My ecu doing all the decisions, and is able to lower the boost for what ever reason if neaded
Like I said re map first as it isn't just about raising the boost. It's also about the fuelling & ignition timing. The boost controller can give you a more consistent pressure & eliminate surge especially with a twin solenoid unit. Lee
