Bolt on pedals
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Joel white, Dec 2, 2020.
  1. Hey guys I’ve just bought myself some new pedals for my meg 250 but they’re bolt on pedals with washers, from what I’ve seen with the original pedals they look like they’ve been hooked on by bending the metal.... so I was wondering if bolt on pedals are even an option help would be appreciated
  2. Post the pictures of pedals you bought.
  3. yes correct the surface of factory pedal is just tin with some tabs bent around the plastic pedal, for me the throttle pedal was not in correct L/R location or height so i drilled and attached an after market pedal raising it slightly with good heel & toe lip
  4. I agree on throttle pedal position - it felt too far away from the brake. I removed the thin Aluminium cover, to drill the standard plastic pedal body behind it. It’s easy to unbolt the pedal and it also has a simple wiring harness plug. It’s dark down there! So you don’t notice the black plastic pedal behind it.
  5. How did you guys remove the original tin pedals, and should I be careful drilling into the pedals underneath don’t want to damage sensors wiring etc
  6. matt e
    there rivets so need the head drilling off
