Got an issue with the blowers on my RS250. Everything appears to be working fine but no air is coming out of the vents. Tried switching off and back on again, tried on all different settings etc but nothing. The blower is blowing as you can clearly hear it but nothing is coming out. Any idea?
You sure its blowing? Bring it to Renault and have them hook it up to Clip, they can access the climate control computer and reset it. I once had that the blower stopped working, caused by water hitting the blower resistor due to clogged up drains around the windscreen wipers. A quick reset by Renault solved it.
Well this is totally random and pi$$$ing me off! It works for an hour or so all is fine, then gradually gets slower and slower and warmer. Then it comes back on again! Definitely not a pipe issue as it still comes on randomly, and its definitely blowing as you can clearly hear it even when hardly anything is coming out.
Similar thing happens in the 172/182 years ago it was a heater matrix. Just an idea although I would of thought renault would fixed it 10+ years down the line.
