R26 Bleeding brakes ( new braided lines )
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Beasley230, Jun 24, 2014.
  1. Fitted some HEL braided lines to the megane the other day , quite happy bleed them out pedal was okay, not amazing but good !
    Drove about 100miles and the pedal went crap again, so this morning I bled them again , both rear brakes and both sides of the fronts, inner first then outer, pedal feels better than ever , but still not rock solid like my 182 with braided lines. :/
    I'm was going to use a full pressure bleeder on Saturday as I've just been vacuuming them of the caliper nipple and topping up , but read just that there's something on diag (clip) for brake bleeding ?
    Am am I wasting my time and need clip ? Or shall I just crack on ?
  2. Nah the clip will help u out if u suspect you've got air into the abs pump, the correct procedure is , RHR LHF LHR RHF
    i had a similar issue when bleeding mine, the sequence is key :smile:
  3. I'm pretty sure the sequence on Clip starts left hand rear and works round in a clockwise order
    And if you've got air in the system the only way to get it out is with a Clip to operate the ABS
  4. Have you checked the pistons are all working and the pads are not jammed with a bit of corrosion ?
  5. I did it so furtherest away from master cylinder so , RHR LHR ETC as you say mate :worried:
    It had new front D+P , rears aren't great but free enough!
    Will take the rears apart and pressure bleed it , if that's still not great , I'll get Clip on it I guess ! :@
  6. Or an RS tuner with the relevant module.
  7. Got air in the abs sounds like, need clip really to pump cycle or eezibleed and a good couple of litres to flush.
    I did the same on mine when switching calipers, cleared all the air, constant fluid for ages then a massive bout of air again. Just takes time but when it was done my brakes were better than ever
  8. I keep reading how bad they are to bleed , going try it under pressure if there's air (excluding the abs) that'll get it out haha !
    If not I'll have try clip ! Didn't know you could do it with RS tuner though! I'll see what's easiest , don't think anyone I know has a RS tuner :/ I sold mine a while back :@
