Bleed screw on thermastat
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by imprezaworks, Oct 25, 2015.
  1. Im checking for an air leak and i assume one of the bleed screws is on the stat? Before i start can anyone just let me know the process please. I have type d coolant at the ready :smile:
  2. Checking for an air leak but messing with coolant confuses me.
  3. air in the coolant mate
  4. So you want to bleed the system.
    First run it upto temp with expansion tank open they that first
  5. Yeah sorry my explanation probably wasnt great.
    So run the car upto to temp with the cap off with the heaters on full heat?
    Unscrew the bolt on the housing. I had a quick look (in work today) and assume its the top bolt nearest the pipe?
    Then the coolant will start to come out and check it runs smooth?
    Cheers for the advice by the way
