Black ph1 225
Discussion in 'Megane Projects' started by F3x, May 18, 2016.
  1. F3x
    F3x
    Hi all,
    Time for some details :smile: got it about 6mounths ago. Don't have many pics but I will post them in the future.
    Mods/work done so far:
    - Decat 3"
    - 630 injectors
    - powerflex suspension bushes
    - arms ball joint
    - inner + outer track rod end
    - arb drop links
    - anti twist links
    - new engine mounts with powerflex inserts
    - powerflex arb bushes
    - ramair filter
    - chinese ic
    - cl pads
    - oem r26 shocks
    - eibach springs
    - silicone hoses
    - dump valve
    - iridium sparks
    - steering rack bush
    - oem front wheel bearings
    - swivel bearings
    - boost gauge
    - quick shift
    - clio cup wheels + ns2r
    - ph2 rear lights conversion
    From top of my head I think that it's all :smile:
    Now i'm having a strange vibration @2500rpm when i'm off the throttle... Any ideas of what it is?
  2. matt e
    pictures dont work
  3. I get this same vibration it's quite a strong vibration as well. I have vibra techincs engine mounts and it's only done that since I got them fitted so my guess is because you've put the powerful power flex mounts on yours
    F3x likes this.
  4. F3x
    F3x
    Little update.... Scorpion catback fitted
    martin1977 likes this.
  5. F3x
    F3x
