250 Bit of help please
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by jack250, Dec 18, 2016.
    Are these two both engine mounts?
    The one to the left is making a bit of a noise when I wobble the engine?
    This is just under the driveshaft. Is it meant to have a nut as well?
  2. Yes they both are 2 engine mounts and no it doesn't have a nut....
    jack250 likes this.
  3. Cheers mate. Take it there shouldn't be any noises coming from either of these two? It's a squeaking noise I'm getting from the left one when I move the engine manually. Also getting a knock from that area when driving. If I blip that throttle something knocks when the weight is transitioning...
    Does this sound like the engine mount is on its way out?
  4. From the picture it's clear to see the rubber disintegrating, that means your dogbone mount is kaput my friend
    Sent from my VIVO using Tapatalk
    jack250 likes this.
  5. Cheers mate. Which one is the dog mount?
  6. -Jamie-
    The bottom one
    jack250 likes this.
  7. Yes one below drive shaft
    jack250 likes this.
  8. Cheers chaps. And that looks knackered to you?
  9. I had that knocking sound and I ended up replacing all three engine mounts plus the gearbox one as well, and it stopped the noises
  10. Even the one you pointing your finger at looks knackered mate
  11. I've done the gearbox mount already. So you would reccoment all 3? Stick to OEM? Don't want all the vibrations from upreatd stuff really
  12. -Jamie-
    Vibratechnics lower dog bone and fresh oem will be fine.
    jack250 likes this.
  13. Nice one Jamie. So just these 3?
    Bowen likes this.
