Best PTFE spray for dash sponge
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by 328isport, Jan 6, 2016.
  1. Hi All,
    Just trying to find out from experience what spray is considered the best when it comes to spraying the dash sponge to stop rattles.
    I have GT85 which allegedly contains PTFE, but not sure if this most suitable or whether I should go for a more specific dry PTFE spray?
    Obviously I realise it needs to be clear/invisible!
  2. WD40 do a silicone spray which works really well
  3. +1 on the wd40 silicone spray. Works well for me, lasts a good year before needing redone
  4. Cheers guys, and did you try to press the foam down a bit when you sprayed it or did you just give it a good dowsing all the way along?
  5. That'll be the one. I just sprayed it along the full length of the foam.
  6. Where specifically should you spray this to stop this problem, where the dash meets windscreen ?
  7. matt e
    Yeah there a foam strip which you can see where the dash meets the windscreen
