Best actuator
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Graemeshaw, Apr 3, 2016.
  1. Hi all
    I'm wanting to change my actuator as it's not holding boost as well as it was on my 225
    Is it best and cheaper to go after market (ie forge)
    Or fit another standard one?
    Are the forge ones easy to set up ? Or a pita?
    Graeme
  2. I'm sure the Forge ones are the only aftermarket ones available but I've seen mentioned on here that the 250 actuator is supposed to be as good as the Forge.
    I had the Forge one fitted to my last 225 & it worked really well.
