Hi, What rebound and compression adjustment setting is recommend on the BC Coilovers 10kg/7kg for track?
Sure its only compression that adjustable. Will depend on what the weather, track condition and tyre. I run 20-25 clicks from full soft, front and rear on a smooth track in the dry and that's on 595rs-r's In the wet, 5 clicks front and rear running Asymmetric 3's On the Nurburgring, in the dry i use 5-10 clicks front, 5 rear as its quite bumpy Thruxton i would soften off slightly as that is also bumpy but very grippy.
