Battery problem
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Josh_s 1991, Aug 8, 2018.
  1. Recently had a new battery on my megane old one was dead. When driving the car hard i get a battery light come on the dash to the right of speedo and also the stop sign lights up. Anyone else had this problem I have no idea what it could be? Battery is brand new thought this would sort the problem but it hasn't.. help. Many thanks
  2. Probably a loose earth cable. I get it sometimes straight after hard acceleration, stays on for a few seconds then it clears.
  3. Does alternator charges your battery properly?
    Way to check is:
    start engine
    Get voltmeter prongs on battery terminal
    Should read around 14V ish.
    If reading is lower then alternator does not charge the battery at all or not enough.
    Josh_s 1991 likes this.
  4. yes could do this -or- get one these and have constant voltage supply monitor
    https://goo.gl/j6hjEV
  5. Sounds exactly the same as mine ! It says ok after and goes away
  6. I have bought something to check it, car is still under warranty until 2020 so will not have to come out of my pocket if new alternator is needed
