Hi everyone I own a megane rs 250 2010 and need a new lower suspension ball joint has anyone fitted one of these before and what problems have you had. Cheers
No problems at all but you need to press the old one out and press the new one in,I did it several times.....
Is the ball joint different than the one from a Clio 200? Because I have one left from a Clio if I will need it for my Megane.
Clio 200 and Megane has the same ball joint ,you can't push it out by hand you need a press to take it out...
Although you can knock them out with a big lump hammer and a bar/thick punch This is what I started doing on mine - they fail regularly!! And sticking them in the press has its risks so a hammer is safer if you can do it that way.
