Badge Glue Removal
Discussion in 'Exterior & Bodywork' started by gazmidas, Feb 12, 2015.
  1. Evening!
    Does anyone have any good advice on how to get the megane badge glue off the rear bootlid? Got tge chrome letters off, so just left the the glue.....
    Wd40 and fingernails dont seem up to much.
    Gareth
  2. Rub it when dry with a micro fibre cloth , should just rub off
  3. warm water with some fairy liquid and a microfiber cloth
  4. To remove mine, I just used the hairdryer sparingly and an old bank card. Took 5 mins and then finished it off with good old fashioned rubbing
  5. I shall try all these combinations tomorrow! Thanks
  6. Old card to get letters off comes off so easy,Hairdryer to warm and peel glue off or use tar remover and then quick polish the area jobs a good one.
  7. dont need hairdryer for that little bit, i used some tar and glue remover, but your just as easy letting it soak in warm soapy water for a bit thenrubbing with microfiber
  8. Autosmart Tardis will get it off.
  9. Old card to get letters off comes off so easy,Hairdryer to warm and peel glue off or use tar remover and then quick polish the area jobs a good one.<br/>
    That's how I did mine as well m8
  10. autosmart tardis or any other tar remover should lift it however you may still see some remains in critical light if so some kind of paintwork cleanser car remove it completely. auto finesse tough prep is brilliant for this kind of thing
  11. Microfibre cloth did the trick followed by a bit of polish :smile:
