225 Bad Engine shake
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Pinkie, Mar 27, 2015.
  1. So I recently bought a Megan Sport 225 and love it to pieces but it has a whacky engine shake. Could this be due to a spark plug not firing at lower rpm or an electrical fault?
    I have a video of it that I will link as soon as it finishes uploading.
  2. Here is a video of the engine shaking and crazy noise coming from the exhaust, my father says it is missing.
    [video]youtube;4yr3eLrFK4c][/video]
  3. Injector or plug if you're luck
  4. Unplug your coils one at a time to find which cylinder is missing.
  5. Is the engine management light on? If so get it plugged into a quality diagnostics computer which should aid with the fault finding.
  6. Nope, sometimes it says "Check ESP" after I go over rough ground and the engine shakes like crazy when I try to give it some beans. It does the shaky thing often after a cold start or when I park it on a slight hill, but this one was really bad right after a short drive.
  7. Check the lambda sensor's wiring. this can cause issues
  8. Check the engine mounts
  9. As said above most likely a bad spark plug or coil. Engine mount may be knackered because of this but not the cause.
  10. It has a new engine mount.
  11. Have you unplugged the coils to see which one is misfiring?
  12. Not yet no. I have 2 car people coming around today to have a look for me and to check the coils and whatnot.
  13. A knackered dual mass flywheel will also give this symptom at low rpm/idle
  14. Any joy fella ??.
  15. No luck yet, it started raining and I had nowhere dry to put the car to check anything.
  16. Gavin.
    Gavin. RSM Admin
    I keep reading this, my brand new dual mass fly and paddle clutch does it at low revs. It worries me.
  17. I pulled the plugs and checked them about 2 weeks ago, haven't had a shake quite as bad as the one in the video since.
    I didn't really do much, just took them out and put them back in after checking them. It seems to have done something.
  18. Scan the car with an obd interface, u shuld get a missfire message on a cilinder, then switch coils 2 to 4 and 1 to 3, scan again and u`ll confirm.
  19. Just got my car back from Renault ($1800 service...) and the car runs perfectly now. They must have found something up and fixed it while I was there.
  20. You've paid all that and didn't bother to as what they have done, surely just out of interest
  21. It was way overdue for it's 100,000km service + timing belt change and I just had no spare money to buy an OBD.
