Back box dropped
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by markc, Sep 2, 2013.
  1. Flipping rear box rubber mount broken. Exhaust is now resting on the rear valance. Ill try kwik fit in the am I think, hopefully they will have a rubber mount bracket. I hope it's just not a Renault only hanger/mount.
  2. You could always cable tie it up in the mean time so it's not resting on the paint?
  3. Salty
    Salty RSM Moderator
    renault only mate but not too much
  4. I will tie it up in yes, it's got a bucket under it propping atm. Dealer it is tomorrow then, thanks chaps :0)
  5. Cable ties win
  6. jubilee clips work aswell, plus they dont melt :smile:
  7. Daz
    I really do need to get a new set of these actually, even though there is nothing wrong with mine I've not long had the lower bumper painted due to it rubbing at some point and don't fancy having it do it again!
  8. Ok, got the part today from Renault Manchester. Fitted this evening, seems ok although slightly different then the original. The new one seems to just hang from the rubber after the top bolt and the 2 in the exhaust were tightened up. There are 2 side straps that catch the weight when pulled down. The old one had a separate bracket and a different side strap as I can make out. I will keep an eye on it........
  9. Daz
    I must have one of each then as I'm pretty sure mine are different!
  10. end in 448?
  11. Will.
    I left mine too long and it's ruined the paint on the bumper :worried:
  12. Not sure Ads, can't find the blinking bill. The old one had a top bar with hook, and a side piece.
  13. Does anyone have a quick idiots guide as to where these are? My backbox is touching and starting to damage my bumper and I can't get to a garage for a bit.
  14. ones on the right hand tailpipe the other is on the box on the left.it will make sence when you're under the car i promise!
  15. Cheers Ads, I need to try and tie wrap the bugger up until I can get to the garage!
  16. This happened me last week. Took to a local performance exhaust centre and the made me up 3 brand new mounts that take any rubber. Solid as a rock now!
  17. Same here mate, damn annoying!
