250 B14 kit VS new shocks and lower springs
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Matthewdemin, Aug 14, 2019.
  1. I changed the front ARB and it makes it a bit flatter cornering, didn't touch the rear.
    Because I was on standard springs and dampers I found it is the best way to firm it up o turn in (and bushes refreshed) without going coilover route.
  2. I changed the front ARB and it makes it a bit flatter cornering, didn't touch the rear.
    Because I was on standard springs and shocks I found it is the best way to firm it up o turn in (and bushes refreshed) without going coilover route.
  3. Thanks Rich
    What sway bar you have ?
  4. I went with the whiteline one in the end, I've had their bushes in the past with no problems.
  5. Jamie Atkinson had a uprated front arb for sale
  6. I have only one question
    oem sway bar 24mm and Whiteline also 24mm !! what is the difference ?
  7. My OEM bar looked smaller than the whiteline one but I didn't measure it. The main difference was the whiteline one felt stiffer with less flex.
  8. thanks !! gem 22 mm!! I made a mistake
    richmillions likes this.
