There's a 'click' in the steering wheel too. Only happens when stationary and turning wheel left. Advise is appreciated as always chaps. Note...Just had both swivels changed. Cheers
Still getting this noise. Had another good poke around but can't work where it is coming from for the life of me. No ideas chaps?
I've done this a couple of times already mate. The noise hasn't got any worse for a couple of months which I was hoping it would so I could get to the bottom of it. It sounds as though it's coming from directly inside/behind the hub around the drive shaft. I can also make it do the noise if I hold the wheel at 9 and 3 o clock and pull one way/push the other.
Potentially, but these have been changed in the last 12 months. Is it difficult to get the bearing out of the hub to have a look/change?
