Hey guys, i see someone messing around with a clio 172 standard radio. By putting an Aux input adapter cable into the back with a jack end so your able to play music through your phone ipod etc is this the same for the megane 225 2006 as i dont really wanna change the look of the inside. Any input would be great Thanks
If it says update list at the bottom right then it will work. Simple case of connecting cable the kit and feeding the aux cable through wherever you want. I did this myself last weekend.
I did this on my r26 I used this cable http://www.ebay.co.uk/itm/3-5MM-AUX...LIO-MEGANE-LAGUNA-SCENIC-iPhone-/262063603674 You also have to go in to a ‘hidden’ menu on the head unit to enable aux.
Not really a hiden menu, just go into your settings and there should be a setting for aux to turn it on.
But how to recognize the good update because it is quite complicated for those who do not know how to handle the tool.
