Aux belt change RS250
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Nick-ST, Aug 2, 2018.
  1. Evening all
    Have any of you changed the auxiliary drive belt on a MK3 RS? For whatever reason the previous owner of my car had the cambelt done but not the aux belt. It is starting to look very tired and probably a little bit noisier than it should be. Have changed a few belts over the years. Just after any hints and tips before I attempt it next weekend
    TIA
    Nick
  2. Go in through wheels arch liner, I found much easier to rest long extension on an axle stand to apply force to tension pulley then slip old belt off and new on while holding tension, much easier with two people
    Nick-ST likes this.
  3. Thank you! No special tools needed I take it? The Renault kit I bought appears to have a new tensioner as well!
