225 ASR/ESP Foult if hard accelerating
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Shymek, Aug 13, 2014.
  1. Flashing only when I;m hard accelerating on 3rd gear and above. First and second gear are ok.
    When ARS/ESP Foult are on dasboard - asr don't work (shoud be self activated after 50km/h).
    Where I should looking for problem? With this foult turbo load sometimes 1,4BAR and drops and sometime 1,6BAR in peak and 1,5BAR to the red line.
    It's problem with trothle or first MAP sensor?
    Thanks for help.
  2. Ok - I found why I have problems with accelerating :smile:
    Message ASR/ESP FOULT is when I have overboost. MAP sensor I only to 250kPa (100kPa fot atmospheric and 150kPa for real boost).
    So now another question:
    If standard MAP sensor (Bosch 0281002616) is only to 250kPa, can I change them for another Bosch MAP sensor which is to 300kPa? (from 1,9dCi versions and also from Megan 250/265: 0281002566)?
    Probably I must reprogramed map of MAP sensor - is this posibble?
    I want to make more than 1,7BAR boost :smiley:
