Anyone help a novice with what these are on the engine...
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Stephen Portlock, Sep 13, 2020.
  1. Evening guys!
    I’ve had some great advice on here since getting the 225... I was wondering if anyone would be willing to teach me what these parts of the engine are? Trying learn as much as possible about the car. I know a fair bit about cars but this engine is all new to me so any advice would be great.
    Attached is a photo which hopefully shows what I want to know haha... trying to keep it simple.
    I know the blue forge pipe needs changing, I’m on the case
    Also, noticed the clip on the coil pack has snapped and lose. Tapped it up for now but wanting to know if you can buy and replace the connectors?
    Thanks guys!
  2. 1. Electronic throttle body.
    2. Fuel gases recycling valve.
    3. Turbo press control valve.
    About the coil conector, is a common fault. My old 225 had all 4 broken. I´d looking for replacement conector but never found they. I´d block they with a little plastic clamp.
  3. The coil connectors are the same as Toyota Lexus 1JZ 2JZ on ebay.
    Stephen Portlock and manugtt like this.
  4. For the failed coil clip I’d get rid tape it’s going fall off and run cable tie between the two wires and around coil itself, will last for years
  5. Good to know, thanks mate! Loads available on eBay
    was thinking this... only have giant cable ties at the moment haha!
