225 Anyone do radio codes??
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by mike_snowdon, May 25, 2016.
  1. After a disconnected battery, found out I don't have the code for my standard radio.
    Anyone able to help?
  2. ianplymouth
    Hi Mike
    I used an app on my phone called "Renault code scanner" you will need a number off of your radio, so you will have to pull it out to find it, then enter the number and it will tell you the code.
    mike_snowdon likes this.
  3. Look up FREE RENAULT RADIO CODES on Facebook. I used them 2x weeks ago. Worked Perfectly!!!
  4. That app works perfectly,I was almost faced with a 13 hour drive with no music but it saved the day lol
    Just a tip,if you have nothing to remove the radio, buy some wooden skewer things from Tesco for a quid :wink::smile:
  5. ...or, use u- shaped corners from a wire coat hanger. Less likely to snap than wooden skewer, (but still take care).
  6. ^^^ +1 :smile:
  7. I can supply radio codes as I work for a main dealer if anyone is stuck.
  8. google it. there's a free batch file that you input the last 4 chars of the serial number and returns the right code.
    No need to pay for a code.
  9. I've got a app which does them now [emoji106] so if anyone needs a code let me know.
  10. I'm stuck! Which code is it???
  11. Would be something like these, 1 letter 3 numbers
    E.g. L326
  12. That's what I put into the code finder right?
  13. Yes or put it here and I'll send you one
    You my friend are a lifesaver.
  15. 8557
  16. It says code error?!
  17. Oh dear it definitely says 8557 should be the code.
  18. 8421 comes out to me for r541 through 4 diferent code calculators
    Sent from my LG-D855 using Tapatalk
  19. Ok I'll give this one a go when I get in! Thanks for your help chaps.
  20. 8421 is also what I get.
    S.
    MilosB likes this.
  21. The second code worked! Thank you so very much.
    MilosB likes this.
  22. Your welcome.
  23. Which website you using??
