Any benefit to running Forge recirc valve over a standard OEM ?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by DrewG, May 9, 2015.
  1. Hi All
    Any benefit to upgrading / replacing an OEM Recirc Valve on a 225 with a Forge unit ?
    Thanks for any advice / comments...
    Drew
  2. If the recirc valve is "tired" ie if the membrane, is worn, spring losen etc. The forge should seal better for sure.
  3. No, unless the original unit is faulty and leaking.
  4. thanks both
