Another leak thread
Discussion in 'Exterior & Bodywork' started by Chriswright, Mar 17, 2014.
  1. Hi,
    Couple of weeks ago I noticed I had damp carpets so out came the interior, cleaned the scuttle drains and I thought everything would be fine. The water isn't coming in from the usual place, instead a hole by the drivers door. Ive had a guy come out to look at my windscreen and after testing it with me it seems the water is getting in somewhere behind my drivers front wing. Has anyone else had this issue? Depending on how my car is sitting depends if it leaks. Basically I can't park anywhere flat without getting a pool of water in my drivers footwell!
    Any suggestions?
    Cheers,
    Chris
  2. Does it come in if parked with the drivers side up slightly? Mine did that, was coming in through the door speaker.......
  3. No I doesn't come in then. It's definitely not coming in the speaker though. You can see where it comes in through one of the holes by the door, below the A pillar if that makes sense?!
