alternate way to fit brake ducts
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by rockabilly, Feb 5, 2021.
  1. so on my 250 i have a19 row oil cooler behind the bumper on the pass side and the original washer bottle on the drivers side. i did not want to loose either. so i have done this method. trail and error really. so as you can see i cut holes in the front bumper. then on the rear fitted 50mm duck to 90 50mm elbows through holes i drilled in the underside of the bumper. i then routed the duct as shown. will see how effective it is once on track lol. also its higher than the front splitter so in theory so be safe lol.
    p.s i inserted 50mm waste pipe in the ends and painted black to stop the pipe folding in and fitted mess to stop marbles finding there way through IMG_20210203_103845.jpg IMG_20210203_103916.jpg IMG_20210203_110653.jpg IMG_20210205_140723.jpg IMG_20210205_140736.jpg IMG_20210205_144652.jpg IMG_20210205_144657.jpg
    James B likes this.
  2. also to remove front bumper is only three zip ties on each elbow
  3. nice bit of ingenuity there, be nice fit some type scoop at the intake and really ram air down pipe
    also to note after conducting some air flow tests involving 3 different types mesh and industrial power fan the type mesh you're used across the FMIC was best a slowing air flow (or best at blocking air flow) best air flow was using fine chicken wire type mesh
    rockabilly likes this.
  4. might change the mesh lol
  5. I quite like that! What are the bends from?
  6. Just ebay
  7. Nice work!
    I've just ordered some ducting to do the same, although I was going to do the same as Jamie and run it through the arch liners as I've not got an oil cooler. I like this idea, though. Tempting!
    Link to the duct I ordered: https://www.ebay.co.uk/itm/Revotec-...Fits-51mm-Duct-Hose-152mm-x-51mm/310985770918
    (It's a 'Revotec Rectangular Intake Duct - Fits 51mm Duct Hose 152mm x 51mm' in case the link doesn't work after the auction ends)
