aircon removal
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by harveym3, Jul 19, 2016.
  1. hi all has anyone removed the aircon from a 225 if so is there a diffrent auxiliary belt you can get ??
  2. matt e
    I think there was someone on here removed the air-con and used a Clio 197 accessory bracket with pulley
  3. ianplymouth
    I have removed mine, just removed the internals of the pump and bolted it back on, same belt and fixing.
  4. if you do work out how to remove it, can i buy the pipe that goes from the inside of the car down to the bottom of the condenser off you? :tongueout:
