225 Aircon/heater booster fan prob
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Beast31, Jan 31, 2016.
  1. Howdy gentlemen and ladies
    My car's aircon is playing up and the heat is scorching about 50degrees celsius
    When I start the car and switch the AC on it blows strong then gradually lowers it self until it stops blowing at all while driving. When I stop the car and adjust it manually it blows again.it had removed the fan previously and saw it was not making proper contact with the battery wires and it worked fine after that until now
    Its as if it's not getting enough power
    Please assist me
  2. Probably needs regasing (and checking for leaks) if the refrigerant is low the pump will go into self protect mode due to lack of lubricant
  3. I think that might true because I know my gas is low but does it also affect the functioning of the fan
