Aircon cold weather
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by reklaw_11, Dec 28, 2020.
  1. Does the outside temperature need to be of a certain range for the aircon to work? As it’s like 1 degree at the minute and it has kicked in but normally works when it isn’t so cold?
    RS 250
    TIA
  2. I thought that ac would not work when the temp was below 3 c might be more as the condensation could freeze ?
  3. Yeh I think your correct, thanks
  4. Depends most run as a heat pump so it can be inverted, such as the condenser effectively becomes the evaporator visa versa. In mine and previous cars/vans always use it in the winter heats up quicker
  5. Don’t really know but I always use my AC in winter as it helps as a demister.
    engine killer likes this.
