225 Air con joints
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Frizz, Jul 28, 2013.
  1. Does any one have pictures of where the aircon rubber seals are?
    I think I have a leak somewhere. Only checked and re gassed 2 months ago.
    It's going in Tuesday local aircon specialist place to get checked out.
    Just don't want ripping of to change a 50p rubber seal.
    Cheers frizz.
  2. hi mate there is seals an most parts of your ac system but the most comon one's are both seals to your condenser (in front of your radiator) and both seals to the acumulator ( behind tht o/s/f bumper corner) but make sure that the system has no gas in it before you check.
  3. Is it going to be bumper of to check these?
  4. Daz
    Yup.
    Try the one that goes into the rad next to the pressure switch. That's the one that was perished on mine anyhoo.
  5. Well it's the pipe from the accumulator to the bulkhead.
    Part no 8200241440
    The one with the filling valve in.
    It's also a generic part on any megane so you could find one at a salvage yard if needed.
    New pipe ordered from ads@renault.
