As title, im looking for an aftermarket intercooler and actuator for a 225 megane rs Please let me know if you have anything for sale!
I'm in the process of getting a JC Weldfab custom intercooler made. It will be similar in size to a forge cooler, will also have the shroud, be cheaper, half the weight and essentially not suffer from the heatsoak the forge/KTR coolers suffer from. Once mine is made (and back to back testing done), and jigged, I'll probably organise a group buy on them. If you can hold on for a month, it'll be well worth it.
Hi guys! I need a help about the forge actuator for a 225 rs. Is it a plug and play? Because during the fitting i must unscrew a lot the regolator...the wastegate pin was too far from the actuator. Is it normal? The "zero point" of the wastegate should be remain the same. Here two photos...old and new. Thanks very much!
