R26 After market head unit Back to standard
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Losi_8_boy, Dec 29, 2013.
  1. Is it a straight swap back to standard, I miss my controls on the wheel.
    Do I need my radio code? If so where do I get it from?
    cheers
  2. R26
    R26
    Yes you will need the radio code. My radio code is stuck in the front of my service book.
    Should be a straight swap so long as the dash surround it sits in hasn't been cut/modified. You'll just need to remove any wire and dash adapters if installed.
    Can't you just get the interface cables to get the steering controls working?
  3. Cheers mate, I think I just fancy putting my OE one back in
  4. CJ_RSport
    CJ_RSport RSM Moderator
    You should be able to buy an adaptor to plug steering controls into a branded headunit pal
  5. I bought mine from dynamic sounds on ebay, cost £20 for the non canbus version or £30 for the canbus versions :smile:
    works a treat
  6. CJ_RSport
    Cheers torch il have a look myself as want to change to a double din screen type
  7. Just to reiterate, you can buy the connector. I think my double din Clarion one was £20 and worked perfectly. You do lose the clock display though, such as temperature, station etc.
